Wanted 4-wheel drive solenoid
Granger, IN
Anybody have the two (working of course) 4x4 vacuum solenoids that mount on the firewall on pass. side?
fj62 vaccum selenoid fix-max valve
here it is again for the 100th time
Fix for Vaccum Selonoid Transfer Switch
By Keil Thompson
Here is the solution if your vaccum selonoid fails:
Parts:
mac 35a-aaa-ddba-1ba valve 12v 2 each total $ 34.00
arrow asp-1 exh muffler 2 each total 3.20
28-4-2 parker fitting-qty 4 each total 0.44
Grand Total for two complete valve assemblies $39.64
Installation:
The mac valves have three slots for the fittings.
I used teflon tape to get a good seal.
The exhaust fitting goes in the top numbered 3.
Install the parker fittings in the other two screw intakes>
The line from the manifold goes into the fitting that is marked 1
on the mac valve.
The line from the transfer goes into fitting marked 2.
Cut the old wire leads off and connect the mac valve leads
connect the vaccum lines.
I formed a mounting bracket out of aluminum.
To find mac valve dealer go to www.macvalves.com
I got mine here in ga. from tsi solutions 770-879-3500 but i think
that they only sell in georgia
