4-Wheel Drive Problem?
I was running if 4-High the other day. I went to back up (a full sharp turn) and noticed that the front axle was binding as if I had applied the brakes. If I make a moderate turn in reverse - no problem. It happens when backing up either left or right sharply. I was on dry pavement.
Is this a problem or is this just the difference in turning circles.
Thanks
I think you are correct. in reverse at full turn the front will travel on quite a bit larger radius than the rear, and with a tcase that is "locked" the rears are traveling a shorter distance than the front, so there has to be some give which results in scrubing of the tires.
If you want to see an exageration of this watch a rig with front and rear lockers turn sharp on pavement... and listen for axle shafts to snap.
You should take your rig out of 4wd when driving on dry pavement, it will be much better for trhe drivetrain.
That's a darn good way to end up needing a new pair of Birfields! DON"T DO THAT AGAIN! :doh:
