The G59 trans came on early 90's 4 cylinders with the ADD front axle, and has a chain driven transfer case. That's the one you don't want...
G52 came behind the 22R and the G54 is just a heavy duty (beefy bearings) version of the 52 I believe...
Been looking around on here trying to suss out differences in trannys (transmissions, not sexual ambiguity; a whole 'nother post). And leaving men in dresses out, I'd say I'm still a bit confused.
I have an '80 with a 20R and a cast iron 4 speed box. Works like a charm and low miles on the gearbox, but I'd like to get some reduction in RPM at highway speeds without sacrificing the durability of the box that's in there now.
I have read elsewhere that the early 5 speeds 81-83 ? are no bueno... is this so? and what then is preferable? Bolt in swap is best....
I'll be looking around behind barns and such most likely, so years / models most likely to contain such gearboxes are a very helpful hint. I am not in a hurry, just want to get the search rolling.
suggestions?
