I have a 4 speed tranny which is mated up to a split style x-fer case in my fj40. I pulled this tranny - xfer case out of a 76 fj55, and up to two days ago I had assumed it was a 76 tranny. I was wrong! I now have a shiny new orion xfer case just begging to be put into my rig, but the orion case is not compatible with my later model tranny. I am going to purchase an earlier model tranny but was wondering what the differences between the two trannies were? are the external dimensions of the two transmissions similar, or am I going to have to modify my transmission hump cover? will this new set up of the early model transmission and orion case be significantly longer or shorter than the set up I currently have (will my driveshafts need length changes?) Also, as if these questions arn't enough of a PITA, I am also running a Marks Adaptors 350 conversion (also taken out of the fj55) for the later model 4 speed transmission, does anybody have any idea if the earlier model transmissions will be compatible with this adaptor?
Thanks for any and all responces
