Wanted 4 speed dust cover FJ40
Cologne, MN
FOUND!!!
I’m looking for a dust cover for a fj 40 4 speed. Let me know what you have. Doesn’t need to be pretty, just functional.
there are 2 different housings depending on year
there is 1 bolt hole in a different location
it depends on if the bellhousing was for a 1 piece transfer or a split case, or if it has bellhousing mounts or a crossmember mount
just make sure you get the correct one for your application
It’s the cross member mount. If the 2styles are the same shape, I’m fine with relocating a hole. I just need it covered😊
