4-speed assembly issue
Buxton, ME
So it started with a oil leak in the transfercase. Ordered a rebuilt kit and started to prep for pulling trans and transfer out. While draining the oil in the transmission it was dirty so I firgured I would open it up to look around. Decided I should pull it part because of the amount of crud inside and clean it up. Using the repair manual from Specter I pulled it apart and cleaned all the pieces. Everything was going great and had the input, output, and countershaft back in. Tested that it was working as it should before putting covers on. Here's the problem. I installed the front and rear bearing retainers and now the input shaft, synchronizer, and clutch are too tight. Third gear side of clutch is fine. While in neutral shafts only spin together. Any ideas of what might of happened before I say screw it and order a rebuilt one?
You have not installed the transfer case yet.
When you do, the torque of setting the input and PTO gear/spacer, support bearing and tailshaft sleeve will draw the transmission tailshaft snug against the main output bearing and you will have your clearance.
Patrick?
Patrick?
Hi Mark,
Yes this is Patrick.
Thanks for the info. That’s going to hopefully save me. I was very frustrated lastnight.
I didn’t find that one of my parts vehicles has a 4-speed in it also. So if all else fails I will pull that one out.
Thank again
Patrick?
That worked Mark. Thank you.
Glad to get that off my plate.
Glad to help. ;)
