Calling all transmission gurus!
A couple of days ago my stock 4 speed started making some new noises. It's had the usual gear noise of a used 35 year old tranny for some time now, but these noises rather concern me. Initially they only occurred in 2nd and 3rd, but yesterday they also started happening a little bit in first gear. Then I noticed this morning that 4th also started to chirp a bit but not much or for very long. It only happens when the tranny is under load and particularly when climbing a hill. Doing 65 on the freeway everything sounds normal. The syncros are working fine and it doesn't pop out of any gears. It sounds like something is scraping. I put the T-case in neutral and went through the gears, but other than the gear noise it was quiet. There is a fair amount of vibration in the shift lever. I have not had a chance to pull the drain plug as yet to see what might be accumulating in the bottom. I did check the levels on both the Tranny and T-case, both were full and nothing floating around in the top end of the gear oil. I've had to work late for the past week or so including through the holiday weekend so doing much about it has been difficult. I am taking Friday off so I can check it out a bit more. Definitely will be pulling the drain plug to see what's up there.
This is my daily driver, uh my only driver at the moment and can't afford to have it laid up for very long. I have neither a place to work on it or even a place to park for a more than a day. The ol' gal lives on the street. It seems like I need to rebuild the tranny or replace it with a rebuilt one. I'm not up for just putting another used one of unknown condition in. I called around and no seems to have a rebuilt one ready to go in except SOR, but they seem pretty pricey. However it would be down the shortest amount of time just swapping it out with one of theirs.
My main concern is that something is getting screwed up that'll leave me sitting by the side of the road. I don't know enough about trannys to be confident driving it. And I'm not smart enough to park it.
Any thoughts about what's going on inside?
I feel a bit of relief having a somewhat definitive answer to my problem. Now if it'll just last that long. I'm happy to have AAA! On my way over to Jim's I noticed that the scraping/chirping has almost gone away. Evidently whatever was being chewed up has been digested and left me with noisy gears.
It doesn't sound as bad as the scraping did, but still...
