4 Spd Compatability??? Early "vs" Late (tcase??)
dieselcruiserhead said:
Also i was wrong also about moving the crossmember, it does not get moved, I guess they are the same for all fj60's. i am pretty sure all of these errors are from the old LCML, because I have heard all of these for years and turns out none of them are true...
There most certainly are different crossmembers for different year FJ60s... but since they are located under the tranny, it wont make a difference in this case. The difference has to do with the rubber mount and the angle of the tranny. as long as the bellhousing, the crossmember and the rubber mount are from the same vintage as the truck, you are fine. Trying to piece it together will make you crazy if you werent aware of the changes.
Any split case will mount behind the later FJ60 4spd, but the issue for the H55f is with the early cases and the lack of the oiler cup provison.
Hey Brett
I think i wanna go with the 3spd you mentioned and make it a column shift! I heard the gears are very easy to find when shifting! :D
