i need a little help if anyone can throw some beta my way, i've searched this forum and not found much, though i'm sure it's been beat to death on here at some point.... first of all i have a fj40 with 3 speed t-case and i'm using a 60 series rear axle, i want to do double triangulated 4 link on the rear of my 40 but i believe that i'm going to have some clearance issues with my driveshaft, the place where i need to put my crossmember for the bottom links is basically right beside the tcase output and just slightly below, they will be close to pivoting on the same axis as the cv joint. i believe that i can finagle a crossmember that will go over the cv joint then down and across to the other side but it looks like theres going to be very little space between the top of the passenger side bottom link and the bottom of the driveshaft....my main question for now is will that clearance maintain itself during articulation or will my d-shaft at some point hit the link? ....if yall think that the d-shaft will indeed eventually contact the link then i have to decide whether to maybe raise my drivetrain up a couple inches or just go with a single triangulated 4 link and mount my lowers to the outside of the frame....
but the newer BF1A don't gonna make much diference in the 4 link setup in terms of space.
for a trail fix. They were too low also. Some updated pics in the Ga. Cruiser Forum:
Leave it on & yer handcuffed
