4:88 Gears
Just got 4:88s installed with 33's. Feels more peppy around town but a little too many RPMs on the highway. Going to move up to either 34 or 35 inch which should feel better cruising. Mine make a little whine when coasting, which I am not sure is normal or from a bad install. They are Nitro, and I think they are one of the better ones out there by the reviews I have read.
With my 315 Toyo's going up hills in my neck of the woods (30-250m above sea level), I cannot maintain speed (120kph) on one particular hill (with it floored). This is with stock gears and no load, so I can only imagine it loaded up with 1000 lbs of stuff at higher altitudes and going up longer/ steeper inclines. I can live with it, but I can definitely see why others would need/want to regear.
Not really, check ur math on that one first.
Stock tire size is 31.3" with 4.10 gears, move up to 35's that measure 34.5", an increase of 10%, which would require 4.52 gears to match stock, so 4.56 will do just fine.
Yeah, you are right and that must be why I took algebra I twice. Ran the numbers again through the calculations and coming up with a 4.56. I think I had originally had that number two years ago and then added bumpers, skids, sliders, winch and drawers and selected 4.88 as where I needed to be in the powerband with 35's.
Thanks:flipoff2:
Thanks for all the input. I'm going to shop for the best deal on 4:88's...also thanks for the warnings on which brands to avoid:cheers:
Thanks:flipoff2:
Yeah, getting your power back from the added weight of gear & accessories is another thing, these rigs just don't have the power they should've came with. :flipoff2:
Happy with my 4:10's and 37's:flipoff2:
Until something breaks then that will change
I did that for a bit while I was waiting for my gear guy to get some free time, it was okay, but I got back 2 mpg after I got the 4.88's in. Was it worth the extra $1k spent, at 15k mile per year it's saving me $850 per year in fuel, so yeah I think it's worth it since this rig is the family hauler and DD.
Does this mean 5.29s?
My wife's truck has 5.29s and 35s and I have 4.88s (with a blower) and 35s. She really likes the 5.29 gears a lot.
4.88 with the blower is a good combination.
Hadn't planned the blower. Haha.
For that matter, haven't planned past the initial purchase....except 37s and assumed 5.29s.
So...no weakness in the 5.29 vs 4.88?
If you are going to make the effort to crack the diff open, add lockers while you are changing gears. Of all the things you can do to your 80, adding lockers will increase its off-roading capability the most.
4.88s are used most often with 35 inch tires and 5.29s are used with 37 inch tires.
I have factory lockers, and they work great! I want to regear and have been under the impression that 4.88 is the optimum way to go considering strength/reliability of gears. From posting this thread I am now feeling that 5.29 may be the overall best way to go. comments???
Go all the way with these rigs. That's the long and the short of it.
Are you running 5.29's? If so how do you like them?
