4.88 gears opinion on driveability
What size tires?
Should be perfect.
I bought my 200 with 4.88. 6 speed trans.
I’ve put almost 100,000 miles on it.
I’ve had it on 33s and currently 35s.
I have absolutely zero complaints. I wouldn’t have it any other way.
With 35's, you'll have *slightly* higher rpm at a given speed than stock tires and gears, but not enough that you'd really notice. 4.88 is the perfect gear set for 35-37" tires. If you plan to keep the 35's, I would consider this perfect. If your goal is a more stock cruiser and you think you'll want to go back to 31-33" tires, then maybe hold out for a different truck. Or if you're handy, you could probably trade+cash for someone's stock diffs.
I assume you have a 2008-2015 6-speed cruiser?
You'll be 10% over-geared with 35s, with some requisite efficiency loss, but generally is fine. 4.3s are more ideal and too many subscribe to the more is better. There's a balance.
33s will only make is worse with higher RPM and windage losses. Though aero and tire rolling resistance is a factor too, perhaps more significant to MPG
Here's a reference and tables
Ye
Yes, looking at purchasing a 2013. I'm concerned with increased highway noise due to higher RPM as my wife is going with me. Dont want to substitute one drone for another:)
Ye
Noise shouldn't be much of a concern. I've towed on trips thousands of miles using 4th gear at highway speeds and that's much higher RPM. The 5.7L is silky smooth and refined at what will only be 200-300 RPM higher in 6th with 4.88s.
This ^^^
My 200 is not any louder at 4,000 rpm than it is at 2,000
Mileage takes a hit on the highway but without a trailer I’ve had not issues cruising 95mph in 6th gear with 4.88s on 35s. Wind noise from my roof rack is worse than the engine noise.
If you tow I have slightly different opinions
