4.5 vs 4.0?
Im looking for a 90-97 FJ with locking diff. If i have my info straight they started having the Diff lock starting with 93 FJ? i typed in 4.5 vs 4.0 into the search and got zero threads, i would think this would be covered, where can i get some specs on both engines? wich one is more reliable? wich one is beter to put on SC? wich one is more fuel efficient? any info on the 2 different engines would be awesome.
1991-92 got the 3FE (4.0L; 155 HP, 220 lb/ft), but no lockers.
1993-97 got the 1FZFE (4.5L; 210 HP, 280 lb/ft IIRC), and got the lockers + a FF rear axle, rear disc brakes, and ABS. Though you'll find some oddball 93-94's with rear drums.
95-97 with the exception of a few 95s left over from 94 have the updated OBD-II computer which is desirable.
Try doing a search on 95-97 and also search for a look at Lantank's MAF housing that accepts a contemporary model MAF sensor. You must have an OBD-II (95-97) model computer to make the modification offered by Landtank needed to update the MAF sensor. The contemporary MAF sensor has gained an increase in all around performance for all of those reporting results with or without forced induction.
If you are planning on a supercharger you will want the MAF upgrade which means you will need to have an OBD-II computer. Apparently it is a must for forced induction since it allows for more precise mixture of fuel and air.
Here we go again.
The engines are generally referred to by their designations from toyota, which are 3fe for the 4L and 1fz-fe for the 4.5. Cue the 3fe powa guys in 3, 2, 1.......
I'm hear, now we got some ballast.
3FE, POWA!!!, 12" Slee, 1Fz waaa waaaa, Head gasket' = bulk rate, 8.0:1 compression, 35's and you mean I have to re-gear?, snorkel, Supercharger, weak, dog, need 1,000h.p to get grocery's....
X2
I enjoy my S/C and my Landtank MAF. My 4.5 L 1FZ-FE was kind of a dog before these mods. Also, OBDII is great because I love my Scangauge II onboard diagnostic computer. Real time gas mileage,intake temp, and trip calculator are sweet, not to metion its many other functions.
Still working on the lockers though:frown:
Locking F&R diffs was an OPTION in 1993-1997 US Spec 80-Series.
You are going to have to get more creative than that. There are dozens of discussions of these engines and their specs. As 60wag mentioned, they are referenced as 3FE (for the 4.0) and 1FZ-FE (for the 4.5) Are there some specific specs you are interested in other than the torque and hp that Lane already gave you?
Some consider the 3FE to be more reliable. I don't know but there are 1FZ-FE engines that are running around with over 300,000 miles and have never been opened up (incl HG) and there are 3FE's that have blown the HG with less than 100,000 miles. In the overall scheme of things, both are very reliable engines. IMHO, the number of failed HG on the 1FZ-FE would give the "more reliable" award to the 3FE.
The S/C from TRD does not work on the 3FE. Fitting the S/C to 93-94 creates an issue with fuel management but many are running the S/C successfully. You just have to know what you are doing.
Both engines are gas guzzlers. The 3FE in an 80 is probably a little worse than the 1FZ-FE. Not much different in MPG though.
The 1FZ-FE is a 24 valve, DOHC, fuel injected engine with many modern features and many engineering features that are supposed to give the engine a very long life. The NCF has a great section on the 1FZ-FE engine and you can learn a lot about it by reading that manual.
-B-
