3rd Row Seat not latching
Help. My 3rd row seat (passender side) is not latching on to the bed. It sits wobbly and doesnt seem to securely clicked on. I notice that there's a missing plastic washer around the hook on the seat. Could this be the cause of it? Does anyone know the part number?
Thanks in advanced.
Cheers
Bob
Which part are you speaking of?
HTH's!
Mot :)
Is the hinged part folding out all the way? I suspect the little rod that pushes it out got bent, and now your little hinged leg isn't extending down the full 90°. Pull the top carpet out if you have it, just to see if everything is lining up. You may just need to smack that leg under the seat towards the center of the truck to get it to fold out a little more.. if that works then next time your seat is out bend that rod a little straighter with your hands. hth..
My third row passenger doesn't like to latch either. I'm pretty sure the rod is slightly bent. (I tried to straighten it, but it's tricky to get correct.)
To get mine to latch: while the seat is still up, I unhook the rod. Then I lower the seat with one hand while folding down the latch assembly with the other. Once everything is lined up, I climb in the truck and sit down on the seat a couple of times until it latches.
-Lance
I was having the same problem with my rear seats until I just detached the bar part#79093 from the anchored bar on the wheel well and let it hang. That is what allowed the latch to move out. I didn't consider that it might be bent so do what nakman suggests. If that doesn't work just do what I did. I thought that was the way it was supposed to be, hanging down. I didn't read the instructions.
The part number was from the above.
also check the strap that you use to pull and unlatch the latching mechanism. Mine was kind of sticky once and was being held open. Once i jiggled it a little, it latched great.
-Lance
Lance and I are talking about the same thing.
Yup, I notice the bar is slightly bent and tried to straighten it. It seems to do the trick. Seat is latched to the floor. Thanks everyone for all your help!
Thanks mot for the diagram, I notice the missing half circle rubber washer is from the metal hook that latches to the side bar. This is part 79041B.
