3rd member
Austin, TX
I need to strip the parts cruiser, but I have a problem. The driver's side front axle housing is bent about 30 degrees backwards, and I need the 3rd member. The bend is on outer end of the housing. The passengers side axle is out, and everything is loose on the drivers side, she just ain't coming.
My first thought was to cut the axle housing with a torch, but I wanted a few other opinions before the neighborhood became en fuego. I'm not sure the joint will hold the two halves of the axle together if I decided to hydraulically extract it. What would you do? Can I punch something through the middle?
Please advise.
I forgot to add... the window mechanisms for the FJ62's are the same as the FJ80, except for an inch where the glass attaches to the scissor arms. That's a minor detail. The door lock actuators are different as well.
I'm on a project get my brothers '90 62 going, and I have many good parts from a 91. It'll be a fun week.
Have you tried unbolting the diff to see if that gets you any wiggle room?
You know the diff is probably jacked as well.
