3rd brake light retrofit
Utah
I just acquired an LED 3rd brake light from a later model 80. For those of you who don't know, 1991-92 80s never had 3rd brake lights, they weren't required until 1993.
Question:
There are two round fasteners on the back of this thing, but the way it lines up with the liftgate makes me think that there is some sort of bracket that the light attaches to, which I don't have.
Could one of you 93-97 guys go check it out and let me know what you find?
TIA
-Lane
Lane,
Is this what you're looking for?
You know where I got the pic/diagram from. :D
I looked at mine and it's pretty much how it's shown in the pic that mot provided. The only place I can even see it mentioned in my FSM is on the fold out schematics in the back which brings up a good point: do you want to mess with the factory harness to add the wiring for this "high mount stop light" as the FSM calls it? By the way, it is LEDS, not bulbs, stock from Toyota per the drawing. HTH
I got it for three reasons:
#1- I wanted a rear fog lamp, something that I can switch on during those nasty snowstorms; we already had one last week, I couldn't see anything past 1000 feet even at 1 PM :eek:
#2- For basic safety; proven that people react faster to LEDs than conventional bulbs
#3- I want one of those things that GreatLakesWaterjet made that goes over the light :hillbilly:
Lane,
FWIW, I believe they have a specific guidelines/regulations(?) for rear fogs, such as the position/location of it, etc... I know they do, at least in Japan anyway. :hillbilly:
So you using the high-mount LED's "might" not be a legal/effective(?) way to accomplish what you're after in that manner.
HTH's and FWIW!
Lane,
HTH's and FWIW!
Well if the cops can see me from afar, then the light is doing its job. :hillbilly:
Besides, all the Audi drivers have their rear fogs on all the time, even though they have no idea what they do cause the fogs can't be seen from the front... In any case, I've never seen anyone pulled over for it. :meh:
Lane,
:hillbilly:
I was just saying that I've seen it (here) that the rear fog should be at a certain level from the ground (no higher or lower than a specific range). That's all I'm sayin'.
I'm not going to feel sorry for you if I see you pulled over by UHP during a blizzerd one of these winters. :D ;)
Lane,
This is what I've found to be the regulation in Japan:
-You can only turn it on when either the headlights or the fog lights are on.
-Even then you should be able to turn it off and you should be able to tell whether it is on or off (light indicating).
-The mounting height (upper) limit is 1.0m (3.3 ft-ish) and the lower limit is 0.25m (10"-ish) above the ground.
-It is at least 100mm (4") away from the stop/brake lights.
-If you're installing two, then they have to be symmetrical (sp). If installing only one, then it should be on the driver's side.
-You cannot mount more than two.
-It has to be red in color.
ANYWAY, US/UT law might be slightly/a lot different, but just to give you an idea...
Lane,
That's cool. I've never seen regulations for rear fogs.
Though AFAIK (with a little research), rear fogs don't appear to be regulated in the states...
Lane,
Here's what wiki had to say about the subject:
Automotive lighting - Wikipedia, the free encyclopedia
Rear fog lamps
(ECE Regulation 38, SAE J1319)
In Europe and other countries adhering to ECE Regulation 48, vehicles must be equipped with one or two bright red "rear fog lamps" (or "fog taillamps"), which serve as high-intensity rear position lamps to be energised by the driver in conditions of poor visibility to enhance vehicle conspicuity from the rear. The allowable range of intensity for a rear fog lamp is 150 to 300 candelas, which is within the range of a U.S. brake lamp. For this reason, many European vehicles imported to the United States have their rear fog lamps wired as brake lamps, since their European-specification brake lamps may not be sufficiently intense to comply with U.S. regulations, and in North America rear fog lamps are not required equipment. However, they are permitted, and are found almost exclusively on European-brand vehicles in North America — Audi, Jaguar, Mercedes, MINI, Range Rover, Saab and Volvo provide functional rear fog lights on their North American models. The final generation Oldsmobile Aurora also had dual rear fog lights installed in the rear bumper as standard equipment.
Most jurisdictions permit rear fog lamps to be installed either singly or in pairs. If a single rear fog is fitted, most jurisdictions require it to be located at or to the driver's side of the vehicle's centreline — whichever side is the prevailing driver's side in the country in which the vehicle is registered. This is to maximise the sight line of following drivers to the rear fog lamp. If two rear fog lamps are fitted, they must be symmetrical with respect to the vehicle's centreline. Proponents of twin rear fog lamps say two lamps provide vehicle distance information not available from a single lamp. Proponents of the single rear fog lamp say dual rear fog lamps closely mimic the appearance of illuminated brake lamps (which are mandatorily installed in pairs), reducing the conspicuity of the brake lamps' message when the rear fogs are activated. To provide some safeguard against rear fog lamps' masking of brake lamps, ECE R48 requires a separation of at least 10 cm between the closest illuminated edges of any brake lamp and any rear fog lamp.
HTH's!
Mot :)
Yeah, I actually came across that.
I'm gonna do it anyway. If I get ticketed for it, then I'll "fix" it. :D
