I picked up Chris Beggerly's 4" lift from Tom at Hell Creek in New Albany on Wed evening. While I was there Tom really came through for us by offering another complete 4" lift for an FJ40 for the SCC raffle. Thanks Tom!
Tom also let me know that the 60/62 4" lift is currently in testing on a 62 in LA that is planning on being at the SCC. Greg, do you know who this could be. The kit has an option to include drop brackets for the tranny crossmember so the front driveshaft has necessary clearance and welding can be avoided. If you want to notch and weld your crossmember, you don't need the optional drop brackets.
Tom did ask for our help on one issue:
Early 60s (81-84?) had a different transmission crossmember. He needs a very accurate measurement of the frame bracket that holds the crossmember. The measurement needs to be center to center of the two bolt holes that attach the crossmember to the bracket. This will determine if the same drop brackets can be used for early 60s, late 60s, and 62s. Barry or Jack, can you get us this measurement? Thanks guys.
Lash,
We'll be putting that lift on Marty Cannon's 62.![]()
Maybe I'll be able to figure out what a frame bracket is.
SWEET! Can't wait to hear some feedback and see it at the Southern Cruiser Crawl at Gray Rock.
Do you plan to document the install for future reference?
Please keep us posted.
Follow the transmission crossmember to one frame rail and you found it. It is welded to the frame and the transmission crossmember bolts to it. It may be hard to see because its on the inside of the frame rail and the crossmember hangs under it. If you can just measure to the center of the bolt heads, that would do it. They should be the same on the left and right side.
Thanks Barry!
I can't believe I'm the first to post after registering!!
What do I win??
A one night stay with Jeff in his tent.
TJK
Sounds great. We look forward to your feedback.
We have a couple of 60s in our area that need a quality, made in the USA, made in Mississippi lift!
