3rd advice
Arizona
I am getting ready to put air lockers in my rig and while I was in there I was going to re-gear and replace all the bearings/seals. I was looking at buying these master install kits, knuckle rebuild kits and replace the wheel bearings.
Should I buy these "kits" or purchase the parts from Cdan? Is the quality any better with Toy parts? Would it be cheaper to buy from Cdan?
Any recommendations to do anything while I am in there? I do not mind doing the work I am just new at the 80 series and want to make sure I do not take the same thing apart more than once like I already have. :D
In my experience, the Yukon kits often use the same exact brand of bearings as OEM, so I always used the kits, it's nice to get everything in one box, shims, stake nut, etc. But, I never use the kit pinion seals, they are not as good as OEM. I toss them in the trash and get the real thing.
The Koyo bearings you buy after market are slightly different than the OEM Koyo bearings. Below is a picture (stolen from Zuk) to show what I mean.
The taper is way different. That can't be a good thing. Possibly not able to handle extreme stress as well as OEM. At 1st glance, aftermarket shouldn't be a problem using included races, but the OEM would handle in/out stress better, with it's taper, as well as the rotational.
Aftermarket vs oem
We stock and use the koyo bearings. The aftermarket one there in the pic with less taper is the same as what has been in my own 100 series for about 100k miles including towing, 35" tires etc. The bearing is a different angle, and it is also use oe in some toyota applications. We also finally have the rear elocker bearings direct from koyo. We also have the 32010X bearings from koyo that are required for the arb locker in the rear. Another thing, ARB actually specifies a particular koyo number for use with the RD132 front locker. We recently added them to our shelf, as we use them with arb lockers for govt. contracts, As far as I know, no other supplier out there carries them.
Tony,
Off topic a bit but since you are regearing, and figuring you might want to do some type of speedometer correction, if you decide to go with the Mark's Speedo Correction Box I suggest you install it while you have the front driveshaft out :) - It will be MUCH easier to access the connectors with the driveshaft out, trust me :hillbilly:
I am not planning on any speedo correction at this time. I am waaay over my budget and do not like sleeping in the yard with the dog. I have a GPS that provides my speed that I always have on. This will last me until I get "out of the doghouse".
