3link fzj80
San Clemente
Hi, I am currently 3-linking my FZJ80 with absolutely no prior knowledge on suspension. I’m almost done—right now all I need to do is set my ride height. I’m coming here to ask people who know more than me: how much uptravel and down travel should I have?
I currently have 7 inches of shaft showing at ride height (it’s a 14x2.5 King coilover) with 300/200 14-inch springs. I was aiming for around 5 inches of uptravel and 9 inches of down travel, but I’m not sure what to change.
I also currently have 2-inch longer shock shaft ends, but that still didn’t fix the issue of my uptravel being too much.
Do I need different spring rates?
Do I need a longer spring?
Do I need a third spring?
Any help would be very much appreciated.
I forgot to mention this is also my daily driver…
So there will be a lot of freeway miles And I see that rock crawlers use 1:2 travel ratio but if 1:1 is better for a street driven car I could just go with that
5" is enough with good bump stops. I shoot for 5-6" uptravel. 300/200 is close for spring rates. try them and see how you like them. How long are your coilovers extended? I have king short body 2.5's and I use a 2" longer light spring so that they are always under preload. I'm not a fan of spring tender coils
So you think 7in is enough down travel ? And by extended do you mean how much shaft is showing it from eye of one heim to the other ? And also do you think 7in up travel will also be good? And I think my shock will go down more to around 6in after I put my battery in the car / the hood on / and bumper
yes, plenty.
Fully extended length, from mounting point to mounting point. should be in the info that came with your shocks
yes, plenty.
I got them from fb marketplace so there was no info but let me measure them for you and
It was hard to measure since they are on the car but I got 38in
Ok, yeah looks like you need a longer spring to take up the slack. You can run them like that for now, figure out if that spring rate will work for you. If not, get 1 pair of springs 2” longer than what’s on there
After installing the shorter shaft ends and tightening everything back up we are sitting at 6 1/4in uptravel and one side is sitting at 6in ( will tighten the lower side to make it also sit at 6 1/4) here are some photos of the cars first time standing on its wheels after being on jack stands for 7months…
almost done not much more left to do
Just need to finish my carbon hood and put fenders and headlights on (ofc we had to go with the quad headlights)
