3gallon portable air $89 at SEARS !
I just bought one. The reviews seem good. Until I wire up 240 in my garage for a 60 gallon compressor, this one should get me by for small stuff.
From what I have seen Oil lube lasts much longer then oil-less. I have a Rigid 6 gallon (barely runs a impact gun) dual tank that is oil lube before they went to oil less and Aluminum tank. Compressing Air puts moisture in the tank so always let tank dry after using it. Plus it will smell like straight A$$ if you don't.
Having air is so handy. I use it to clean just about everything including my chain saws. You can also use it to run a siphon jug for pulling fluids (break, tranny, oil). I use it so much I take it for granted and wouldn't have a garage without a compressor. The only downside is it is noisy (mount in another room if you can and poke plumbing thru wall).
Guess this thread got the bump ! Thought I would post a few pictures so you guys can get an idea of the size of this thing.
I like this one a little better
