Hi, I recently bought a 91 cruiser and white smoke has started coming from the exhaust. The coolant levels are quite low so I think that is what is burning, but I'm in no way familiar with this engine. If anybody has experienced similar issues, have you fixed it and how?
Head gasket most likely. Could also be a cracked head/block but those are far less likely. I have a 91 and my head gasket went at 283k miles. I did the labor myself but had the head serviced and checked by a machine shop.
The 3fe is a pretty reliable motor. Mine blows white exhaust all the time in the cold when it's warming up . I am pretty sure it's just condensation or steam. If I let mine run for 10 or 15 minutes on a cold morning there will be a small puddle under my tailpipe.
As I stated on the other thread, I'd bet money it isn't the HG. 3FE motors just don't have HG issues. They have to have been abused like hell. (Overheated A LOT). Pull the plugs and check to see if #1 or #6 plug is steam cleaned. I'd bet they aren't.
My money is on valve seals. I bet you are burning oil. Which is WAY more common with these motors.
I start my 80 in the morning, every morning, and it blows "white smoke" for 5-10 minutes. Has done it for 10, maybe 15 years...
That is the link to what you need to do to do a tune-up. This was put together by @jonheld. He is the foremost expert on all things 3FE. Do this list. Use Toyota OEM parts. You can get them from @cruiserdan or @beno. Or you can get them from your local Toyota dealer. (Cruiser Dan and Beno will have the best prices you can find, and they know their s*** and support the community). After you do this report back.
Seems pretty drastic to pass up the vast majority of 80 series out there based on the head gasket issue. You just purchased a 24 year old truck. Unless it's been meticulously maintained you will have some issues come up. Search for issues specific to the 3FE namely the oil galley plug and vacuum leaks. Also Toyota is starting to discontinue parts for the 80 series and the fj80 was the first version of this series. The radiator and some emission stuff come to mind. Enjoy the truck. Agree with the valve seals until proven otherwise.
I live in southern California, but yeah the weather has gotten a little more.....brisk. low 40s in the morning high 50s during the day. Nothing extreme.
Did this coincide with the "white smoke" and loss of coolant? The reason I ask is that it is common to see more exhaust smoke when it is cooler out. And coolant leaks tend to make themselves known more when it is cool out as well. Look on the right (passenger side) of your motor towards the bottom. Look to see if you see any yellow/green sludge. Also, check all of your hoses. You may be weeping a little bit and not notice a puddle.
So, I've replaced the coolant and found very minor leakage in the radiator (i think) after running it for 10 minutes and letting it sit all day. The next day I started it (in the morning) and much more smoke than before came out. I started the truck later today and there is little to no smoke. I haven't been able to check the plugs cause the freaking giant EFI thing that I haven't figured out how to remove.
The spark plugs are on the right side of the motor, not under the intake manifold. Follow the wires from the distributor cap which should have a rubber boot over it.
