3FE valve adjustments
ELK GROVE,CA
I'm lost on the valve adjustments, I can't find the 2 dots that's on the flywheel per FSM. I see the big dots that's on top of each other only. Also there are some parts thats painted white and black.
Any body can help me
thanks
First things first, have you found the timing window?
Yes I found the Window and turn the crankshaft pulley clockwise and per the FSM I need to align the two small dots to the mark (pin). I can't find the two small dots only the big dots that's is 1/2" on top of each other.
There should be a large single DOT (and when I say dot its engraved in the flywheel) and two small dots, the two small dots are TDC and the large dot is 7 degrees which is your timing mark and they are close together.
Are you turning the crank by the crank bolt (46 mm???) or by the PS?
I think you've found TDC if you have 2 dots. The other, single dot is 7 deg below TDC. Look at the pic above and you'll have a reference for how big the dots are and how close they are to each other.
If you are using the crank bolt to turn it, go slow they are easy to miss.
See my PM about stuck valve. I'm no expert, but I think a bent valve is highly unlikely. Anyone else want to chime in on this? Is it stuck open or closed?
Stuck means the locknut won't budge?
See my other PM about rotating the Cam 180Deg. Its sounding like you might have adjusted them all at TDC and you actually do 6 at TDC and the other 6 at 180deg away from TDC.
Reading the FSM, it says rotate the crank 360 deg after doing the first 6... is this the same as 180 deg from TDC?
Your rotating the flywheel 360 and then back to the two small dots.
Yeah, You're roaring the flywheel 360 degrees, but the Cam only turns 180deg. I believe they are on e 2:1 gear relation.
