History: Last summer did a WHOLE lot of work to the engine including replacing a piston with engine still in. Realize I'm a novice and figuring it out as I go.
Today: A bunch of guys went to a friends property to burn brush, they're trying to get quail to come back. Anyhow, it rained out, and I happened to have my tools (and checked the forecast last night).
We took off the valve cover, then put everything back to try and adjust the valves by ear. Did I mention novice? I didn't know what I was trying to listen for or which valve was making the noise (neither did the geniuses with me). So we adjusted the valves per the FSM and restarted it with the valve cover off to listen. It was a lot quieter. Also, watching the valves move is REALLY COOL! It doesn't take much time hooking things back up to get it to run after the cover is off, so from now on even when I adjust them FSM wise, I'm going to do this.
Oil Issue:
As soon as I got the valve cover off, I knew I had a problem!
And this is what it looked like last summer:
Only 1 tower that squirts oil was squirting oil, #4 cylinder I think. Others are brown as you can see in the pic.
Luckily I was only about 50 miles away. Even luckier, i was about to go on a 200 mile trip!
I changed the oil about 100 miles after the work. I was going to change it again today, but now it will be part of a lot more work.
I worked hard making sure everything stayed clean when I did the work and spent a lot of time wiping and cleaning everywhere I could reach while the engine was open and accessible. I assume this is from a clogged system.
Gameplan - need recommendations:
I'm going to take off the oil pan and make sure I properly tightened the oil pipe(s) up. Then I'm going to start it without the cover on and see if ALL are squirting. Also, I'm going to dig through the FSM to figure out the lubrication system and see what may be clogged up. I believe I'll use compressed air to shoot through the little holes where oil is supposed to go to make sure all is clean.
Comments appreciated.
Joe
Oil Issue:
Joe
