3fe valve adjustment intervals
South west utah
How often should I adjust the valves on my 3fe? And what would happen or what symptoms would present themselves if the valves needed to be adjusted? Thanks guys
Valve adjustment: every 15K miles according to the FSM
Wow that's seems excessive, do people really adjust their valves on these things that often? I am way overdue. What problems could arise from nit adjusting the valves? What would be the symptoms?
Less available power, worse fuel economy. Generally a less efficient engine.
The valves will loosen over time. It happens slowly so you don't notice it, until you bring them back to spec.
You only get 155 horses. Might as well use them all.
Go figure lol. My fuel economy has seemed to get better not worse. I attributed it to new lighter tires. The reason I am asking is because I have started to hear a new noise when I hit 3000 rpm and I am no expert at all but it sounds like it is coming from the valve train and I have never had the valves adjusted in the 80,000 miles I have owned the truck. I will definitely get it done.
