3FE tick tick tick tick tick
Mississippi
Everything I'm finding through search are valve adjustment threads, I don't think that's my problem, although it could be. Seems to be louder under the truck near the driver side. It's not an exhaust leak. It's a steady tick tick tick tick, cold or hot. If it is the valves it's only just one, maybe two. The tick is about as fast as you can read the ticks above hahaha.. Tried to post a video but it says my 15 second video is too large?? How could I compress it? Make it shorter?
THANKS
A tappy tappet is a happy tappet. 3FE is not a quiet engine.
But it seems like one is making more noise than all the others if it's valve train related...
A good running 3FE sounds like ball bearings in a blender. The valve assembly makes noise, the injectors sound like you're tapping on an aluminum can, the multiple pullies and idler wheels along with the fan roaring is ridiculous.
He has embedded a YouTube video, MUD probably has a tiny attachment limit.
My 3fe has never sounded as good as the 'after' version of that video.
Mine sounds like 2 or 3 sewing machines running. I've been pretty good about the valve adjustments over the years too.
THIS IS IT!! This video was in the related videos after i watched the video you posted, but its the exact tick that im hearing, same EXACT sound that my truck is making. Anything to be worried about?
Dude, why don't you do a valve adjustment and see what happens?
I know this thread is old, but my engine sounds like like this as well. Going to adjust the valves but it doesn’t sound like valves.
That last video sounds more like a rod knock to me. I would, however, adjust the valves again to try to rule that out. I had to do it 2-3x to get mine quite as the previous video. I adjusted the valves to the cold settings since I could never seem to get through them before the last half cooled down.
Frank
Try adjusting the valves while the engine is running. After doing so the only tick you will hear are the injectors unless you have other issues like a rod knock. I’m with @elripster on the last video. Sounds like a rod knock underneath and valves clicking as well.
If a rod knock is of concern you might consider what weight oil you are running. If 10-30 or 10-40, up it to 15-40 heavy equipment oil such as the Delo or Delvac brands. If that doesn't do it you might need con rod bearings but they often last for many thousands of miles while knocking.
I can try switching to a heavier weight oil, and I’m going to re-adjust the valves after work today. To me it sounds more like a tick than a knock but who knows.
I tried adjusting the valves yesterday while it was running but one or two of them are too tight so I need to fix that. Not sure if I would double down on the whole it’s running method or do it the fsm way.
Any ideas on ruling out rod knock? I tried unplugging each cyl spark but I couldn’t determine anything from that.
