3FE tear down
Albemarle NC
Well, spent about 5 hours today tearing down my 3FE to do the headgasket. Well, let's just say it isnt fun, but it really isnt that hard to get this far.
Cylinders and pistons were SPOTLESS, but the valvetrain was disgusting. Only one snapped bolt this far, and it was just for the manifold heat shield.
Head is gonna get scraped down and sent off to be milled tomorrow or tuesday. Next weekend will be the fun part of putting it all back together.
good luck logan, glad she got you home and out for some fun this weekend.
Where did the gasket fail?
Also, the cylinder heads look like they have a coating of carbon on them, could just be the light.....
Nice, lookin' good. I like this pic:
I hope that's what my cylinders look like inside.
The head gasket failure is not obvious.
Are the cylinders that clean because of coolant leaking into the combustion chambers?
Piston tops look like they were steam cleaned of carbon...
Can you get us a close up pic of the block side of that iron head?
I looked at the gasket for ages and couldn't find an obvious failure point. I still need to scrape the block side clean of gasket gunk, but I will definitely have a sharp eye out for cracks anywhere. I have no idea why the cylinders are that clean, in reality they look brand new shiny but the light and the coolant residue make it look a little dull. My assumption is that it is coolant that has been steam cleaning the cylinders, is there any other reason? I do normally run name brand premium.
My oil definitely has coolant in it. I tested the oil for coolant by tasting it off the dipstick, and the sweet taste leads me to think that coolant was getting into the oil. My oil also looks watery now after 4k miles and my typical burn of 1.5 quart per 5k didn't happen, oil level is full.
I'll get more pics up tomorrow when I start to clean things up and take the head to be machined.
Did you check your oil cooler before your tore your head off?
It has both coolant and oil in it. I hope the FZJers dint lead you into thinking you had a bad HG when you really did not.
HMMMMM.. pic #1 no clean pistons????
Any clean valves? This would indacate u r burning water
Did the oil look "Gray"?.. this would indacate water mixed with oil.
Did u do a compression test????
By looking at the pics and reading the post i would have concerns that maybe it was not the head gasket.
Jut my .02
Well, if anything you're getting it all cleaned up and have gained the experience of tearing it down and putting it back together. Good luck!
The pics dont do the pistons and cylinders justice. They honestly look brand new. Anything that is on them is stuff that dripped off the head when pulling it. I pulled the oil cooler, found no cracks or anything, it just looked as nasty as every other coolant hose on the engine. This is an odd case here, but with the pistons being as clean as they are doesnt there have to have been coolant getting burnt?
..., but the valvetrain was disgusting. ...
For an F motor that looks good!:cool: They don't have much oil circulation in the valve cover area and most of them that I have had apart were much worse than that with less miles.
3fes are the only ones Ive ever seen like that. 2fs were always clean...
I think it might be cause of higher valve cover temps...
:frown: I had exactly the same thing. Head came off, no obvious signs of gasket failure but they eventually found a crack in a water passage. Not uncommon for 3FEs. Have it pocket ported while it's out. Some porting and shaving should make all that labor a little more worthwhile :)
If u had a bad head gasket u would more than likely have only one or two pistons that were clean.....
