3FE. Should something go here?
Fort Worth
Hey guys.
There is something on the side of the airbox that looks like a hose should attach to it.
I'm replacing the vacuum lines and noticed it. I can't find anything that shows what should go there.
Not the best drawing. Hope this helps.
There may be a diagram on the top right corner of you hood. I can't remember if it had the vcv.
I think I remember it going to the charcoal canister. Let me know if you need a pick of mine.
Can I see yours?
When I was messing around in my engine I noticed two hoses that were disconnected and I can't figure out which one goes where. And I think it might be why my car wont idle.
That's your VCV. It connects to the charcoal canister on one side, and to the intake plenum on the other. The single port goes to the vacuum line rail on the very rear of the engine block behind the valve cover.
The engine vacuum from the rail actuates the diaphragm in the VCV and allows vacuum to pull gas fumes from the tank into the plenum.
It looks like this goes from the distributer cap to the thing you pictured then to a port in the fire wall. Not sure what it is for though.
Kind of interested to see what it is.
So it's open on one end. And the other end terminates like this.
And for context, it is attached to the back of the airbox. And the end that terminates into nothing is on the passenger side firewall
Thank you for the pictures! That's a big time help. Obviously I was missing that hose all together.
Thanks Johnheld. That makes perfect sense.
That little device is probably a check valve then to prevent back flow into the cabin.
That is a good design. Keeps the dizzy clear in water crossing.
Smart Toyota engineers!
Hi Marco, I think that is the diagram from the vacuum system. It took me awhile to see that OP was looking at something else. I could not find the diagram for the distributor vent assembly in my FSM. Ill keep looking...should not be too hard to find in a toyota parts diagram.
he was asking about that vacuum lines that goes into the firewall, the red line is that line...i have verified it from my truck
