3fe Power Steering Pump Issue After Replacement
Valdosta GA
I replaced my power steering due to a rear leak. I got a reman from Autozone. I flushed the system and bled well. There are no bubbles in the reservoir. During the bleeding process with the tires raised, it turned fine. After letting the vehicle back to the ground, it was very hard to turn. I do get some noise but it sounds more like a squeak vs a normal pump whine. I'm kinda stumped and aggravated. Help please.
Aftermarket remans are mostly garbage. I have one in my Land Cruiser that is fine, but it took me three tries to get a good one. The only saving grace is the lifetime warranty. It's easy to change, so change it as many times as it needs to get a good one. Also check what the other guys said.
I agree with @lzeloz. I too have had problems with reman parts being junk right out of the box. I rebuilt my stock PSP with a kit from O'reilly a few months ago (about $14) and it works great. It only took an hour including removing and installing the pump.
If the flow control valve is installed backwards it wont make proper pressure (been there, passed on the t-shirt:hillbilly:). But, you bought a reman, so if everything else is instilled correctly, I would just exchange it for another pump.
I would have rebuilt myself also but the PO broke the tensioner ear off of the pump casting. I'm also searching for the spacer that goes between the tension adjustment bracket and the pump.
Got the other reman in. Easier to turn but still not right. Fluid still gets pretty hot. Turned pretty easy right after the install, then got hard to turn. Ideas Mudders?
