Changed my pcv valve and grommet last night and was wondering: do i need to put hose clamps on both ends of the hose? The entire hose was soft and pliable but was loose and had no clamp on the end away from the valve cover(this side was also leaking oil). Also the side attached to the valve cover had a little spring clamp on it but was no where near snug imo. I could easily pop both ends off with almost no force.
On a second note my engine no longer stumbles on start up
and the rough idle was slightly improved
Next come the o2 sensors..hope this helps the rough idle a little
and the rough idle was slightly improvedNext come the o2 sensors..hope this helps the rough idle a little
