3FE owners, how are you checking compression?
Aggiesdm
***** Regular
San Antonio, TX
What compression gauge are you using to check your 3FE? I've noticed a loss of power lately and have some interesting ticking going on so I wanted to check compression before I took it to a mechanic. Anyway, I borrowed a set of gauges from AZ, but because the plugs are recessed into the block, I can't seem to get the fitting tight in there. The fitting then has a quick connect hose that plugs into it and the pressure gauge. Due to the recessed plugs, I can't get my hands on the quick-connect once its connected as its down in the slot where the plugs go. So if I get it connected, then I can't get it disconnected while its down in the recess.
I know its confusing, but I was wondering if someone could send me a pic of the right kind of gauge to use? What about the old rubber tipped ones that you just press onto the hole?
Thanks in advance
Thanks, I'll try to find one like that.
One on a hose and then twirl the hose
That's what I tried, but never felt like I was able to get a good seal at the plug hole. Felt like I was getting pressure loss and I didn't want to tighten it too much I. Case I couldn't get it to back out.
I thought about trying the old rubber tipped one. Thoughts?
Compression testers are handy, but to get a better idea what's going on use a leak down tester. Provided you have shop air of course.
Like this one. http://www.harborfreight.com/cylinder-leak-down-tester-94190.html
Easy and fast way to see if there is a problem with the rings, valves or head gasket.
Handy for replacing valve stem seals or broken valve springs as well without removing the head.
Lot hanks for link. I wish I would have seen it earlier. Stopped by HF and picked up a compression set before I read your post.
I've got 276K on the odometer and I'm afraid of the compression numbers that I'm gonna find. If their way out of spec, not sure what I'll do. I love my LC, so I'll figure out a solution but hope it's as least invasive as possible.
Out of curiosity, how does it work? Just pressure up the cylinder and see how much pressure leaks out?
Yep just like that. Usually around 20% is normal, more than that and you should be able to see where it is leaking off.
You will hear the air escaping out the intake or exhaust if a valve isn't seating or burnt.
Remove the oil fill cap to see if air is going into the crankcase.
Air coming from adjacent plug holes is a blown head gasket.
Air coming up to the fill neck on the radiator is a blown head gasket.
276K isn't really that many miles.
Try switching oil if you think it's burning it. I've been running Delvac 15/40 since I bought mine. It's what I run in everything.
Plugs look nice and clean so far. Only oil loss seems to be from normal 3fe leaks.
Hey Powermad, see my thread that I started on the compression test. I'd appreciate your input. Sounds like you know what you're talking about.
Lot hanks for link. I wish I would have seen it earlier. Stopped by HF and picked up a compression set before I read your post...
With a little ingenuity and a few parts from your junk box, you can turn a compression tester into a leak-down tester. Just google for "build a leak down tester."
