3FE Overheating
Loyalton Ca.
Hi guys,
I just picked up a 91 fj80 and under load the gauge reads hot. If I am gentle with it I can keep the temp gauge below the red but that is not always possible. The guy before the guy before me, replaced the water pump, thermostat, radiator and fan. He removed the stock fan and cowling and installed some electric fans that blow so hard they sound like some kind of jet. I hot wired those so they are always on, still no love. There is no evidence of oil in the water or vise-versa. When it gets hot it does not leak anywhere it just vents into the overflow. It is my understanding that the 3FE is not too prone to head gasket failure so before I go and start from the beginning any suggestions? These are the new fans.
Start with air lock, check heater heat works. No oil in water and vice verse does not preclude head gasket.
Hose collapsed?
Are the fan's blowing in the right direction i.e. towards the engine.
Are they decent fans, plenty of Mickey Mouse crap out there?
A decent electric fan setup DOES work, but needs to be done properly.
Does it have cats, if so may be a blockage?
Others will be along soon with suggestions.
Regards
Dave
Yep common mistake, fans blowing the wrong way, no wonder people can't get them to work properly!
Unfortunately unless the fan blades are optimised for the correct direction you will not get the best performance.
See if they are a cheap aftermarket setup, these tend to have blades that are swappable (read useless), check them out.
Regards
Dave
@Dave 2000 got this one.
Personally, I'd be hitting up @arcteryx or the pick n pull for a factory set up. The stock setup works very well on the 3FE.
I would lose the electric fans. The OEM setup is quite good at keeping those 155 horses nice and cool. You want an OEM fan clutch specifically for the 3FE with the green hub, a good used fan shroud from a 91/92 FJ80, and the plastic fan from a 91/92 FJ80. The FJ62 version of the 3FE had a different shroud and fan.
Make certain the shroud has a tight seal to the radiator. I used thin foam weather stripping from Home Depot. Works great.
Clean out the space between the AC condenser and engine radiator.
Jon, in the future I'd appreciate you purchasing your foam weather stripping from Lowe's, my employer! Thanks! :rofl:
Nice to know you got it sorted, as above, get yourself a stock setup.
Unless the fan system you have is installed correctly (quality fan, decent wiring, relays, temp switches, and an uprated alternator), you may find when loaded up and the fans are called on to work for a living unreliability sets in.
Given what we have seen thus far from the original install I would pull the electric, and unless you are a little OCD (like me), go stock.
Regards
Dave
