So yea, forgive all grammatical errors due to my rage. I was driving home today and the engine light kicked on while steam/smoke poured in the cabin. At the same time I heard a noise which sounded like a skeleton spanking the monkey in a metal cabinet. A heater hose coming off the water pump had a small slice in it and was spewing steam everywhere.
As things cooled down, I saw what appeared to be steam coming out from under the valve cover or from the spark plug openings as well as the bad hose. I could put pressure on the hose to stop it from steaming, but the steam still came from the cover or spark plug areas. I popped the oil cap and the oil looked like caramelized sugar from what I could tell. I was not able to see all the way into the valve cover. The dip stick was HOT, but not caramelized.
I had my brother tow it home tonight. In which way can I inspect the engine to see if it is still ok(thinking not likely), cooked/cracked, or repairable? I have little information on the 3FE.
Never cooked an engine and I am tweaked right now. Depending on the condition of the engine determines if I will be getting a new rig or not. Other problems (A/C) are also pushing on the vote. Thanks for the help guys.
DYI job to fix, not complex if you take your time, I did it with only a Chilton's and engine hoist (head's very heavy 100# or so). Hopefully the head's not cracked. Have it checked at a shop; they can do the valves too. The block is very solid, so it's doubtful if anything there got hurt. Renew all of the hoses and belts! Have the radiator flushed while you're at it.
Ned
