Hello, yah I know there are lots of o2 threads... I looked thru a bunch of them.
But I did have a question. On the 3fe there are only two sensors both pre cat. LH and RH sensor. What is the difference between these sensors? Why would there be a difference. One does cylinders 1,2,3 and the other 4,5,6. Both are pre cat.
I am in the process of buying some. I would buy Toyota ones with out a doubt, but they are $288.00 each here in Northern BC.
Napa carries NGK ones. Which are $135 for the LH one and $245 for the RH. And in the catalogue it mentions there is a universal which applies to both LH and RH.
Is one heated and the other not? Will I screw things up by putting in the universal.
First off the expensive RH ngk isn't available right now either. And in a week or so I want to drive 4 days each way back to my folks place. And my mileage right now is at 10-11 mpg on the highway.
Not sure if it will get better. But it does seem a bit rich at the tailpipe now.
I am also replacing my spark plugs with OEM.
Thanks, BB
Thanks, BB
They was 90 bucks a pop.
