When my guys pulled the 3FE back in November they didn't label the injector connectors. Now that we have the new motor bolted in we are questioning the order of the connectors to each injector.
I read this: 91 FJ80 3FE fuel injector to cylinder mapping.
Which stated:
"the 3fe engine harness has two branches of 3 injectors each. Wiring color codes are all the same so not important on which order you plug them into injectors."
and
"Correct. 2 banks of 3 injectors. All 6 have a black/green +12 wire and bank 1 (cyl 1-3) has a white/light blue trigger wire and bank 2 (cyl 4-6) has a solid yellow trigger wire.
Don't overthink this as it really doesn't matter."
But how does the ECM know to fire which injector at the correct time? I'm questioning the advice above. Anyone have some insight on this?
Which stated:
and
