3FE hose question
So I'm readying myself for a rebuild, and I was looking over all the vacuum hose lines and noticed two open spots in this cluster of hoses. I was just wondering if something was missing, or if it is suppose to be like this.
Thanks in advance for the help. Sorry I'm a noob DIY guy and a noob to these tanks.
Read the hood
There should be a vacuum diagram on the hood.
Here's what mine looked like before I tore into it:
I believe 5 pipes near fender, 4 hoses go directly to 4 pipes near engine, 5th is for plastic wrapped hose.
Please tell more about rebuild, how far you going?
You have a blown HG, how many miles on your truck?
I have 155k. I just recently purchased this vehicle. I have already had to replace the transfer case, and I need to rebuild my front knuckles as well.
Am I missing something here?
And it looks like my vacuum lines are wrong.
Yea, your vacuum lines are all messed up. Someone was making it up as they went. Follow the diagram under the hood. It tells you where each and every line goes.
Spend some time clearing out the hard vacuum lines. They tend to load up with poop from the EGR system as it ages.
Yeah I will do that, thanks!
new guy here 1st post.
I hope these pics help you guys out, as far as I know all these lines are going to the right places. this 91 FJ80 just passed cali smog.
If anyone needs more pics of anything let me know.
Thanks! I got the vacuum lines all In the right places now and tagged up and removed. Now if I could just find my darn 12mm socket....
4 meters of hose is enough 2 do all 3.5mm hoses on exhaust side engine and all but 3 long hoses to the canister so about 7m should cover the 3fe if you get as 1 continous length i used cotton braided rubber fuel hose (was the cheapest hose could find avoid silicon hose its only good for the 4 small hoses on air box) and put some heat shrink on the ends to keep it tidy if you dont have a vac hose diagram under ya bonnet you can allways mark the hoses with a bit off paint is easy 2 find were go when put back together as a diy head gasket job can some times take a few weekends
