3FE Fuel Pump. Supra option?
Albemarle NC
Well, fuel pump seems to be going out. Driving down the road, it will just completely cut out, no power at all either for fractions of a second or for 10 seconds. I figure it is the fuel pump/in-tank filter, so while I'm in there..might as well replace the pump anyways at 175k. Does the Supra pump fit/work for the 3FE? Will the larger(more powerful) pump cause any harm? Could my ignition coil be going bad?
An ignition problem will be as if you turned the key off. A fuel delivery problem will be slightly more gradual. The first few things that come to mind are the fusible links, EFI circuit, coil/igniter. All of these can fail intermittantly.
Fuel pumps tend to be a long life product.
The Supra pump is not a direct bolt-in and is more expensive. Those that select the TT Supra pump are looking for the higher flow rate which you don't need with a stock 3FE. I think you will be happier by replacing it with a stock unit if yours is bad.
-B-
Could it be a failing Fuel pressure reg? I was speculating the fuel pump for the small stumbles "shakes" my engine ( and many other mudders) get after it warms up but it seems they dont fail often. Someone recently posted about tweaking the air flow meter and going from running rich 9.7mpgs to ~12.9 after on the 3FE. Keep us updated on what you find out
I richened up the MAF (loosened the gear a tooth) and it seemed to have helped my performance, but all this did start AFTER I did that, so I may crank is back a tooth and see if my problem goes away. The FSM really doesn't help me in diagnosing this problem especially since it is intermittent.
I think I will do a little more testing and try to find out my problem.
That was me that did the MAF adjustment. The little shakes after warm up on mine was the air bleed screw on the MAF meter. I drilled the plug and popped it out to adjust. You mentioned the truck dying while driving?? Hmmh, I usually see a fuel pump fail when you stop driving and won't start. I wouldn't be swapping fuel pumps out for bigger ones either. You'll end up w/ gremlins the efi can't control.
I sometimes have the no (hard to) start problem, as a matter of fact that happened today, but the engine has not tried to die on me yet. It feels more like someone is flipping a switch to kill the truck, sometimes it's just for a split second, sometimes it's up to 10 seconds. Letting off the gas will help it come back, and sometimes flooring it will do the same.
Are you sure the arm the slides back and forth on the contacts are touching through the whole range of motion? I hope you didn't knick the contact area and kill one of the segments. It would cause a dead spot on the meter. I use a ohm meter on the MAF and use my fingers to move the door inside the meter. Move slowly and watch the resistance climb. If it glitches or drops in resistance as your increasing the rate of gain on the door then it's not working right. Sometimes if there any dirt or debris then it needs to be cleaned. I use alcohol and Q-tip to clean the contacts with. Silicone the cover back on when done.
