3FE EFI Relay Ground Wire ??????
92 3fe EFI relay Terminal #1 brown is ground Chasis/body for relay coil, #2 red-yel is 12v+ from Efi fuse for hot side of relay load contacts this is the same circuit as ECU terminal#2(BATT+), #3 red 12v+ for relay coil from ECU terminal #3(MREL) This is where ECu controls the relay, #4 yel-red When energized relay provides12v+ to ECU terminals #1(+B1) and #7(+B) also to almost all Ecu controlled actuators(idle spd cont, O2 heaters, VSVs ect), Fuel pump through Circuit opening relay contacts. EFI relay load circuit can be monitored at the FP terminal in the diagnostic connector while problem happens to see if you are loosing voltage (this is a quick test, more accurate testing would involve monitor voltage at each component to check if the wire has problem between components or at splices in harness).
Does your problem happen once per drive or repeatedly once in OD? Anything other than OD affecting the problem?
J
Look in Yahoo 3FE Groups files
Yahoo 3FE Group
You may have to join, but everybody there loves that engine. :grinpimp:
I recall that part #s for individual wires in the relay socket are used to repair the socket. In my case, a new relay fixed all sorts of odd dying behaviors on an FJ62 , but that model's relay is stand alone type.
I'm a member of 3FE, and I couldn't find it after 30 minutes of searching.
Thanks jpw, what do I do to check that FP in the diag terminal? It happens in OD mainly, but has happened otherwise. Happens several times while driving, normally on longer trips than shorter, and wont happen unless im going 50ish or better.
If you have a voltmeter monitoring the FP terminal voltage (should be at charging system voltage minus.-1.0v) will tell you if the efi or fuel pump/circuit opening relay are having an intermittent issue. This is a quick test as this the FP term is at one extreme of the circuit. It is not a all inclusive test as this circuit has many parallel branches that could have a problem and not show up at the FP term. A problem with either relay should show up as a momentary drop in voltage as problem happens.
J
10 years later and I have the exact same problem, going to look at what is discussed in this thread, anyone have any more info on a problem like this?
What is the exact issue you're having?
