- Thread starter
- #21
Well I finally got it all put back together. Thanks Jonheld, for the write up. I followed your procedure with the exception of removing the smog pump (I've got little hands with busted knuckles).
If I could add anything to help out the next guy, I would emphasize:
-you have to take out all three studs to get the water pump out.
-the lower radiator hose consists of three pieces; a rubber hose connected to the radiator and the water pump, with a 5 inch+/- section of hard pipe between the two hoses. The hard pipe is connected to the frame or block with a single bolt. If you remove that bolt, the metal section can move around making it tremendously easier to get the lower radiator hose removed from the water pump and re-installed.
I ended up replacing the water pump, water pump gasket, lower radiator hose, oil cooler hose, heater hose, by-pass hose, thermostat, thermostat gasket and o-ring. Ordered all OEM from Beno (Onur) for around $320 delivered; he was very helpful and got it shipped out to me asap. One thing I wish I would have done was go ahead and order a couple of studs and bolts (water pump to block and thermostat housing to water outlet). They are only $1.50 and there's bound to be at least one that will break.
Thanks again for all your help guys!
