3fe code 12
This is a good place to start:
Sorry new to the forum. It is in a 78 fj40
I meant diagnostic information.
Is it a new transplant?
Was it ever running well?
What have you done so far?
What condition is the motor in?
What was the donor vehicle 62 or 80?
It is a new transplant. Never has ran good before in this vehicle. I have swapped ecu, new tps, new plugs and wires rotor... Egr has been deleted smog pump is gone also. It came to me like this just trying to help a friend out.. I was messing with it today noticed. That if you hold the mass air flow open a. Little bit at slow speeds it idles fine around 1200 rpm but won't idle down any slower with the adjustment screw
Sounds like an air leak to me. The air intake from the AFM (not MAF on a 3FE) to the throttle body must be intact and sealed. The top half of the engine must be sealed. This is to prevent unmetered air from entering the system and screwing things up.
There is no "idle adjustment screw" on a 3FE motor. That "golden screw" above the ISC valve sets the static idle air intake. It will have a TEMPORARY effect on idle speed, but the ECU will continually bump the ISC valve to bring the idle back to 650 because that's what it's programmed to do.
The "Golden screw" should be set to 1/2 to 3/4 turn from fully seated.
Possible places for unmetered air entering the system:
Large air intake tube. Usually tears at the bellows.
Gasket on the oil fill cap.
Gasket on the oil dipstick.
Valve cover gasket
Valve cover grommets
Side cover gasket
PCV valve and gasket
Basically any holes in the top half of the motor need to be sealed or she will never run right.
