3fe alternator troubles
Frederick, MD
I've got a 92 3fe FJ80 that the alternator went out on. No big deal, I just figured I'd order a new one and put it on. After ordering 4 alternators from various different auto parts stores, every single one that has come in has been slightly different from the last, and slightly different from what fits my truck. Finally I just ordered a used alternator off of a 91 FJ80 (seller said it would fit) and what do you know, it's not the same! As you can see from the pic, the plug is different.
So can someone tell me where I can get a damn alternator for my truck?? Including my original alternator, I've gone through six alternators now and none of them have been the same. Did Toyota just decide to make every alternator slightly different or something? Anyway, my truck has put a big dead spot in my yard from being down the last 2 months so any help/insight would be appreciated. Thanks.
Some 92s came with the 80 amp alternator with the external fan. Some came with the 90 amp alternator with the internal fan. The 2 are not easily compatible as the mounting is different between the two.
External fan = 80 amp
Internal fan = 90 amp.
Get the correct one for your truck.
You can play games with parts store aftermarket parts, or you can reach out to the many OEM parts suppliers on this forum.
I ordered a remanufactured denso 80 amp one off rockauto for mine and it fit perfectly fine.
Part Number
Part Type
Price EA
Core EA
Quantity
Total
1992 TOYOTA LAND CRUISER 4.0L L6
PURE ENERGY
14461
Alternator / Generator
Private Label Package
$ 73.79
$ 50.40
1
$ 124.19
My truck has an 80 amp with the external fan, which is what I keep ordering from different places but with no luck. I'm hoping to avoid spending $300+ to get my original rebuilt since I'll just be selling the truck soon anyway
This is the original alternator I pulled off my truck (it's disassembled right now because I took it to a shop to have it rebuilt, then they tried to charge me over double what they originally said, and then they didn't put it back together...)
80 amp OEM Denso unit. Fits 91/92 FJ80
27060-61090
You can buy a remanufactured unit that comes in a red box from any online parts resource for about $185.
So it has to specifically say it's a Denso unit? I've ordered from 3 different places now and non of them have worked, but non specifically said "Denso" either. All just said 80 amp alternator for 91/92 Land Cruiser
Hey there, you ever find the right alternator? I have a 91’ fj80 and ran into same problem with all the connectors being different. I eventually used the one with a port like the one you got from a shop, I disconnected the wires from my original harness using a flat head screw driver and mounted them onto a harness/connector I bought on Amazon. I know nobody like to use aftermarket parts but it’s still the original wires and connector, all that’s different is the plastic housing I’m using from Amazon
