As the temperature has dropped up here, I've had a bit of an accesories electrical gremlin pop up.
Details:
'91 3FE Daily Winter Driver
157K
Replaced:
Fusible Links
EFI Relay
(Start related)
OEM Plugs, OEM wires, OEM cap, OEM rotor, starter contacts, FPR, Cleaned Cold-start injector, COR relay
Symptoms:
-Takes 3 or 4 cranks to start sometimes but always starts (may or may not be related)
-When running any electrical change (highbeams, blinker, wipers, brakes (assuming lights), etc...) the speakers cutout and the headlights dim.
-Battery checked out good
Thoughts:
-Right now this is just a pain in the butt and kind of annoying, but I'm worried that I have a bigger issue on my hands.
-Looking for some insight on where my priorities list should be...
-My expectations are bad ground, bad relay, fuse problem, harness short, alternator, etc...
-I will be getting a multi-meter sometime this week, but any experience with these symptoms and potential fixes would help out a ton.
Thanks!
Details:
157K
Replaced:
Fusible Links
EFI Relay
(Start related)
Symptoms:
Thoughts:
Thanks!
