My check engine light has been on since I yanked the AFM sensor plug wires out of the housing, separating it from the PC board. After soldering the three connectors back onto the PC board, I assembled the three blade connectors, the plastic cover. Then finally, assembled the AFM unit back onto the intake tube.
Today, I decided to check the diagnostics port to get the codes, in an effort to discover the issue (s) I have.
I got the following codes:
Code 24: Intake Air Temp Sensor
Code 31: Air Flow Meter Signal
Code 71: EGR System Malfunction
I noted all of the codes, assumed that all of them had something to do with the AFM issue, then cleared the codes according to the FSM instructions.
When I started the vehicle, the check engine light was no longer illuminated.
I then performed a road test, and immediately noticed an increase in gas pedal responsiveness. Then, all of a sudden, the engine sputtered BIG TIME. I pulled to the side of the road; the engine did not die, but it ran really rough, and at an extremely low idle - as though it was going to die.
The idle RPM then returned to normal after about 30 seconds of allowing it to idle. Then, it began to sputter again. About 30 seconds later, the idle returned to normal. This happened about 4 times within the span of 10 minutes or so.
I allowed it to idle rough for another minute, then normal idle re-appeared; this time, the rough idle did not return, and I was able to drive it home. Not only was I able to drive it home, but the engine seemed to have more power than it did prior to checking and clearing the codes.
Question 1: Is this normal after the ECU fuse has been pulled to reset the diagnostic codes?
Question 2: Although highly unlikely, does clearing the codes change anything in the performance - electrically?
Thanks in advance.
Thanks in advance.
