Afternoon All,
My carb issues continue on my FJ80. I know this is a 60 forum but it’s a 91 3F Carb Aus version. Not the 3FE one. I thought you good people might have more experience of the carb. Anyway chasing hesitation and have done the usual vac leaks, timing, valve clearance, PCV valve etc. Took it to a carb ‘guru’ who found a worn needle seat area rebut with a Chinese top/float body section. OEM Toyo bottom carb.
Now starts fine cold or hot, runs fine for about 20-30mins then will randomly miss, stumble, drop revs, backfire and sometime die. Can’t accelerate past it, will drop revs stumble then pick up sometimes. Sometimes cut out. Sit for 10 secs, crank and away she goes good as gold.
Much head scratching and I found that in the carb sight glass the petrol level is below the bottom lip of glass. Always was in the middle before the rebuild. I’m thinking the guru didn’t alter the tabs on the float to get the right spec. My question is how much of a job to get into carb and bend the little tabs a bit to make bowl fill to correct level?
Cheers
Cheers
