3B Turbo Injection Timing
victoria, BC, Canada
Hello everyone. I just moved up to a 3b in my bj40 (from a B) and I brought my turbo with me. This new engine seems to be in great shape, and I’d like to do everything in my power to increase its lifespan. Only thing I’ve played with so far is the fuel. I did on my B as well, and was always chasing egt temps…eventually I’m going to run a water to air intercooler, but not for a few months at least. Someone told me it would be wise to dial in my injection timing now that this 3b is running a turbo. Can someone shed some light on this? The pump is currently on the factory timing marks on the pump/gear case. I’m running 12lbs of boost at the very most when on the highway, and my temps are manageable, but I’d like to lower my numbers to something more conservative and safe. Would appreciate any input, thank you!
You need to retard the timing as the boost from the turbo increases the compression and can cause early detonation.
It probably won’t help lower your Egt numbers but it will help keep unnatural forces off your crank.
For a non Intercooled 3b 12psi is pushing the egts high here on the hilly island and rest of BC from my experience.
I recommend a small low rpm spooling turbo with a wastegate and keeping the boost to under 10psi. Or intercooling it and still only making 12psi or you will run into heat issues on those 5 kilometre 6-10% hill climbs.
Also something important of note I feel is I did some testing on the 60 series that has a larger intake for the factory air can than the 40 series and I was pulling a vacuum in there under boost so I upgraded the air box inlet.
Retarding timing may make it too hard to start. This is climate/temperature dependent though. I definitely wouldn't advance the timing. It can be tempting and delivers more power but increases stress on the engine a lot.
Thanks Steve. I’m working from home today, so I will be retarding the timing before I hit the highway this afternoon…will report back. After looking through your thread I also do suspect in having restriction issues at my factory air cleaners inlet. Time to get the grinder out!!
I have experimented with timing advanced and retarded on the 3B and it between it having very little adjustment and being a tractor motor I never noticed a difference. With good compression it starts just fine with the timing slightly retarded.
The main reason for retarding the timing when adding a turbo is as we know diesels run by compressing a fuel air mixture until it explodes.
Further increasing that compression ratio by fitting more air and fuel into the cylinder with a turbo causes that compression point of ignition to happen earlier.
The ignition point should happen slightly before the piston reaches top dead centre. If your compression ratio is higher from adding a turbo that ignition happens earlier in the piston stroke it will push against the up coming piston robbing power and causing shock forces on the crank and rods.
Retarding the timing is just moving that ignition point back to just before that piston is reaching by top dead centre.
Yeah that super long hose to the air filter is pretty restrictive. I opened mine up too and everything was noticeably better. Particularly how quickly the boost comes on.
I also retarded the timing a bit. How much wasn't terribly scientific. Likely copied what someone did in this section circa 2005 haha
There's also a trick with playing with the hoses on the intake butterfly. Rotating the fitting with the hole changes the throttle response noticeably. Not everyone likes the change, but it works on my tired old 3b.
There's a thread about it here somewhere, but here's a pic of what I'm talking about. The thread explains it in more detail, I just finished a graveyard shift so if I tried to explain it I'd just confuse myself.
Mine is set around 12 psi which is probably a bit too much, but with the IC my egts are tolerable if I'm not stupid on hills.
I don't worry about it with me driving, but I do cringe if the lead footed woman takes the truck out 😂
I'm in cedar, give me a shout if you're up this way.
So i made a couple changes, i retarded my timing and modified my airbox until I can make a proper pipe that runs to the front of the bay, but for now it’ll work. Before I retarded the timing it was actually a little advanced from the mark, so the truck runs a fair bit different now. I can’t tell if it’s got less power, kinda seems like it, but it does run quieter. A little bit more “knocky” on startup, so maybe I should bring it back a hair? Hard to tell..
The airbox mod made a world of different, turbo spools much faster now and my egts are noticeably lower, but I still plan on doing a water-to-air setup at some point. Once I get bored again, or until the next time I hit the Malahat lol
Probably pulling a decent amount of hot air, but I’ll get to it…
Current timing setting…thoughts? Too retarded? Looks pretty comparably to the pic @stevebradford posted above
Nah I love it. The adjustment setting looks good. If anything you have it nice and retarded now.
At idle it’s slightly retarded ready for the extra compression when the turbo spools and forces more air in under load that inadvertently advances the timing.
If you feel you lost anything power wise I would focus more as you already are on intake/exghust efficiency such as intercooling. You will make that power up by other means and have that power exactly when you need it like pulling a hill with a load.
Seapotato and I experimented extensively with the throttle body Venturi tuning. I think he like likes it still but I put mine back to stock. It does make a noticeable difference but in my opinion the difference it makes is when you feather the peddle it just goes to wide open throttle faster. To me that makes parking lots and low range crawling worse. I don’t mind having a deadish 1/3 fuel peddle feeling, I can get to WOT by pushing just a bit more to the floor if I want.
But if you want to try it all you need to do is turn this top Venturi tube opening in the throttle body from stock hole up to more horizontal.
more air (boost)will cool it, but as you say you need an intercooler past 12psi to take the heat of air compression out of it,
My 3b is on 20psi, venturi adjustment, retarded timing, and intercooled and reaches 1250f max, which is ok for short periods
It's not EGT you should be concerned about, it's mechanical strength. Feeding intercooled 20psi into a 3B is a big risk to the crank.
:hillbilly:
the big risk to my 3b is getting replaced from lack of power
boost without fuel isnt dangerous, timed right (retarded) its just fine
breath of fresh air to an engine that ran too hot anyways
the crank snappers on here were running old leaky injectors, not timed right, too much fuel too early, too hot of a burn without enough air, or mechanical failure due to negligence (or all of the above).... is it more of a risk than not turboed, of course. would i keep the engine without a turbo, absolutely not, and 12 psi dont cut it....
Or perhaps just running twice the torque the engine was designed for.........
As long as you're aware. Lots of people think extra power is free. It was @gerg who said it was like giving grandpa meth and seeing how much he can bench press!
No, i do appreciate the knowledge, but it either does what i need it to or its gone anyways, the right foot is the determining factor
@stevebradford when you are adjusting the timing are you doing it by spill timing or just guessing using the match marks on the pump?
Will eventually like to turbo an old 3B l have in a BJ42 but its still a long way off yet, also have a 15BF that l'm turboing but it runs a rotary pump which l will check the timing. I assume the 15B could benefit from some retarding of the timing once turbo charged?
check the timing numbers on a 15bt to know where toyota thought it should be for a turbo
