3B into FJ-40
Does anyone know of a company making pre-made motor mounts for swapping a 3B into an FJ-40. Does the transmission from the donor BJ-60 bolt right to the crossmember of the FJ-40? Can this pretty much be a bolt in installation?
No, it's not as simple as that. The FJ40 does not have the crossmember used in the BJ40-42 diesel powered vehicles and I'd doubt if a crossmember from an BJ60 would fit.
The B series installation in the 40 series vehicles is different than a gas engine installation in that different front mounts are used, no rear ENGINE mounts are used, instead the transmission mounts to a crossmember under the transfercase.
It is a doable thing but it's not as simple as you apparently were hoping it is. You'll need, at least, the additional crossmember. I'm not sure but there may be a cast mounting point built into the transfercases used in diesel installs and they may be specific to the model series.
email these guys http://cruisercreations.com/pages/diesel.html
they do diesel conversions alot as i hear...they can point you in the right direction :)
