Looking for any information on
this pump
Any and everything, can't find squat on the internet on size, replacement parts, faults to watch out for and especially the timing.What do you want to know about it?
I wrote a couple of small guides for common issues with the 2H version of this pump.. the pumps are nearly identical except that one is 4 cyl and one is 6cyl and they are on opposite sides of the engine. The two guides are entirely relevant for your pump.
Common Leak - Delivery valve gaskets: 2H Delivery Valve Gasket changing - https://docs.google.com/document/d/19SHlXDMITHS1WiQXQa40kXlhrL2GIVzEpbyqhJ73XFk/edit?usp=sharing
Leather Diaphragm breakage - 2H Diaphragm replacement - https://docs.google.com/document/d/1ZPvljDvzPpgPWnViWyJdNVVkYDdpIe9x_ppJcHW3jX4/edit?usp=sharing
If you wanted to do some general reading on this style of pump search google for "Inline injection pump". Some older mechanics refer to this type of pump as a "jerk pump".
The spill timing process for this pump is fully described in the Factory Manual which can be found here:
Thank you, will definitely have a solid read. Any idea on what some pump this is, I have heard that there is a way to decode the model number. More is this a 7,8 or 9mm pump
