3b fuel priming problem
HI all .. well Mike, I thouyght maybe you have poil pressure problem, if you check your inyectors, and glow plugs are fine, the next step is oil pressure, withoil press my 2H engine do not start .. no matter what I can do ..
At least of 10 psi of oil pressure you need to start it.
mike said:
Where and how do I check for oil pressure? Thx
conect a mechanical oil meter in the stock oil pipe. Need have no less than 10 psi.
I recently pull the engine and transmission. I'm in the middle of restoring this vehicle and I needed to get access to the framefor cleaning/painting. I could'nt get it started prior to pulling the drive train. I'll keep you posted> Thx
