39 on 40
Mine are 15's (balloons) Prolly go to 17's when i go beads. Thanks RK, your rig is sweet also. I thought about swapping engines, but ended up rebuilding the 2f, added an rv cam and TBI. Made a BIG difference on and off road.
ya I would like to go 17 but i aready have some 15 beads. and if i had a 2f i would maybe go propain. But I think i rather go 8 and make front end a bit ligther
I almost went propane, but i did'nt want to carry just 1 tank, and 2 tanks would leave no room in the back or a 40.
we used 16's on the burgandy truck in the vid
Where can I find more pic's on this one?
I have plenty...Yes..It was stolen...Then found..Then sold 3 days later....New owner is in Tucson Arizona...I miss it already....s***..I almost cried when he pulled out of my driveway...39's on 16" wheels...one ton axles...front is cut down to 65"..rear is 63"
Where are you guys getting 17" rims with the correct back spacing for cruiser axle. I am not fond of spacers...
Ha! That would be after you witnessed my finding a loose spacer before the rocks a few weeks ago. :D I'll post up some pics later tonight with 38.5 TSL/SX's and the current 39" setup.
SOA 40 on 39's, 17" wheels, 2" spacers, 30 spline longs, 6 stud knuckles, 6 pin drive flanges, Poly rears, fuel injected and DUI 2F runs good well past sideways, blah blah blah...
attachment.php
attachment.php
Haha...well since you are like the 12th person I have seen on the trail with problems with wheel spacers, so ya it sorta helped. Wish I could afford some krawlers but I should be sporting 39.5 Iroks by GSMTR, I am just having some trouble finding rims that wont require spacers.
So what the verdict on the Polys? You get a free set...I still don't think they should have blown. You wernt thaaaat wedged.
I too run 1.5" spacers and 38.5s. I've been running mine for years and have never had a problem with them. I keep hearing about spacers coming loose but of all my wheelin' buddies that run them I've never seen one come loose that was installed properly.
Ordered 17 x 8s crager soft 8s from summit(talked to Calvin ext 5890)but they would only go 2.5 BS not 2"!!!$92.78 each shipped.
In case anyone needed some, that guy knew what I was asking for!!!
Not my post, but Im ordering these today :D right at $400 to my door :doh:
attachment.php
Hey Bill, I've got a pic with that same pose!
FWIW, I had 39" IROKs on 15x10" beadlocked wheels in this pic. You can see how much wider they look than the 39" IROKs on 17x8" beadlocks in the first pics I posted in this thread.
