37" PB Rockers
Frederick, MD
Baby needs a new set of shoes.
Anyone have thoughts on the 37" Pitbull Rockers? I know at least one of you guys out there are running them.
:beer:
I was going to go that route. Tire looks like a great fit for the 80. The only thing that ended up holding me back was that they are bias ply and I do to much on road driving to deal daily with the typical bias ply issues. I ended up going with the BFG KM2s which I really like. Have to say though, if I had to decide all over again it would probably be just as much of a struggle to choose. I had heard they were discussing a radial version... Don't know how true that is though. I'd say go get them and report back for all of us ;).
Kyon
What, exactly, are the considerations once you've gone bias ply? You've already thrown the baby out with the bath water. :flipoff2:
The IROK is a bit of a rock biased tire (for a Swamper), so probably great choice for the Southwest. More mud over rock maybe you go more mud biased in terms of a tire for rock crawling out of the mud.
I haven't seen any people who really deal with gumbo going IROK. Not sure how the PB compare, though. Those 37" competition trxus might also be a great choice for mud with a bottom where you are climbing out onto rock due to the siping.
As with all tire questions, what are you trying to solve for? Clearly not road use, so the differentiation should be easy.
I've too have been looking at these in the 39 range... But the 80 is a heavy beoch and with my rig sitting still months on end before i can run her I've been weary of going the Bias route. Can we say flat spots...
Tired, how do those Irok Bias flatten out when your not moving the rig around?
-Ammo
I've had the bias Swampers on a UniMog and it would sit for long times and the flat spots where never a problem and they didn't grab the ruts any worse that most agresive radials.
I have 39.5 x 16.5/17 PB rockers, and on road I found them pretty good, about half way between a swamper and a radial mud tyre, and about as noisy as a swamper, had them on 17 x 10" rims.
They didnt really flat spot at all while on the car.
I had them on a patrol, which is very similar to a cruiser in weight/setup/etc.
...As with all tire questions, what are you trying to solve for? Clearly not road use, so the differentiation should be easy.
My requirements:
1. True 35" or larger diameter - 37" is my uper limit.
3. Great performance in wet to muddy rocks
2. Rounder than my last two sets of Swampers (LTBs and TrXus)
3. Better mud clearing capability than the TruXus MT
Would also be nice if:
1: I could mount them on a new set ot Toyota steel wheels (16x8)
2: Had decent tread life
:beer:
My requirements:
:beer:
Why don't you try the BFG KM2's in a 37"?
Talking bias ply tires in the same sentence as "rounder" probably isn't what you are looking for - the KM2's might be the balance you need. Outside of that you start thinking more traditional mud tread design like the Toyo MT, but not sure how good they are in the "muddy rock" category.
Otherwise maybe that straight TSL as was recommended, but you'll have to give up the "rounder" given that trxus are probably as good as it gets in an Interco tire. I've had no problems with my trxus - the take a lot of weight but have stayed balanced after 12K miles, but I don't see much mud and don't plan to any time soon :D
I'm thinking KM2...you just may have to go 17 rims to get them now?
I say 36" Irok radials.
I wouldn't put a bias ply on a fat 80 that sees much road time. With the Irok radials I put the effort to ride match them and balance with dyna beads. Having aggressive swamper tread and 13.5 wide, no amount of rim weights will solve the latteral imbalance so dyna beads are acceptable. They don't ride like an AT tire but darn good for what they are. Good enough to take a 3500 mile trip from Texas to California just fine. :cool:
I wouldn't really put the Irok into a rocks only category. Compairing them to my TSL radial spare, the Irok has thinner lugs with wider spacing. I seriously doubt they would let you down in mud that a TSL would get you through. This isn't to say that they don't work really well on rocks even with a full 48psi, well the sidewalls at least. :D
Performance offroad with a 37" PB Rocker = AWESOME. Performance onroad = okay. Noisy, vibration, etc. Typical large bias ply performance. Offroad I find myself going over the same obstacles much easier than the 35" dunlop radial mudders that I had.
Here's the pics. I'm on 4" OME comp springs front and rear, slee castor plates, arb front, 4x4 labs rear, adjusted panhards front and rear, SROR sliders, winch, drawers (heavy), etc...no wheel spacers yet, hence the rubbing in the rear. No rubbing in front, yet. Still thinking about 3 linking the front...
I drive the 80 on road to all destinations. It is only a bad weather, offroad trip vehicle. So having incredibly durable and tough tires with very aggressive tread is what i was looking for. Would not want to put on my wifes daily driven 100 series, though it would look pretty cool:)
