350 TBI questions
calgary
Hello, I am swapping in a TBI 350 out of a 94 chev into our 92 fj80 and i got a couple of questions for those who have done this.
1. Where the heck is the return line for the heater core on the 350? I can see the two obvious ones for the radiator in the front and one on the back of the intake manifold, but cant see the other for the heater.
2. Has anyone deleted the oil cooler, the reason i ask is because the hoses came with it but not the cooler, so i'll probally have to temporarily run a bypass till i can get the parts.
3. what are the 3 fuel lines on the cruiser for? i know the one with the filter is the feed, but there is one with a large canister and a third? do i need all of these for the 350?
Thanks for any positive input, ill probally have some more questions this week.
Cheers!
Should be a 3/8" (IIRC) pipe hole near the front on the passenger side of the manifold. It accomodates a quick disconnect that is notoriously prone to failure. Replace it with an appropriate sized brass hose barb.
The cooler should be neither difficult nor expensive to source used.
The TBI system uses the same 3 lines. You may need to adapt them to the different sizes between the two engines. You might just have to run new lines the length of the truck to get everything right.
Sweet! Thanks Hj60!
I only seen two lines for fuel but i wasnt looking into that at the moment (there is about 6 feet of the 2 original fuel lines hanging off of the motor)
I seen the quick disconnect at the back of the block for the coolant, there is another on the driver side of the manifold but i figured it was to the intake air. Look into that tommorrow i guess. Here is a pic of it, you can see it below the throttle body. It is a pipe that runs to the right and switches to a rubber line.
Also, is there any reason i cant cut down this black bracket on the passenger side front of the 350?
Thanks Again!
