- Thread starter
- #21
if the head gasket is blown, there are 3 ways the water is coming out. 1) into the oil where you'll have a milkshake, 2) into the cooling system, where you'll have bubbles at minimum (after all, upon detonation you have 1500 psi in the cylinders that's now in the water system), or 3) outside the block where you'd easily see it.
You forgot #4.... head gasket is blown, and it's exiting out the tailpipe as smoke. I'm well aware of all of that. Kinda looking for FJ40/350 specific issues
If you just admitted his engine is back into the firewall, that's the culprit. Heat dissipates out the back side of the engine, hits the firewall, and bounces right back into the engine before the non-existent prop wash can blow it out of the engine compartment. This happens 1,000 percent of the time when a motor is crammed into the firewall, and unfortunately the only remedy is re-motor mounting, along with the cost of modified drive shafts and exhaust. You can modify everything else until you turn green, but nothing else will be the remedy- - - sorry.
This is a concern I have. I feel there might be another remedy, but my guess is most FJ40 owners would consider it heresy.... (Cut the inner fenders to allow airflow... and if needed, use over frame headers to divert heat)
That said, the engine is literally jammed up against the radiator (fan is about 1/4 inch away) which may contribute to the coolness. I've seen plenty of folks here who used the stock radiator and a shroud with success...although I'm not sure how many of them had the radiator re-cored.
